DTCp0237
After reading some post on this site it seems I have low boost sensor voltage. Is replacing MAP the only cure. I tried cleaning, didn't find much on sensor.:( Sorry forgot to add truck seems to be running find. the only reason I looked for code was got new ScanGague today and it found the code.
  • Replies 11
  • Views 3.2k
Hey that would be great. Here in N. Cal 88.00. Mine is the flat oblong 3 wire. If you know anyone wants a boost fooler from BD I have one can't use it is round 3 wire.:neutral:
He's looking for this... The one on the right 2001... The one on the left is a 2002... [ATTACH=CONFIG]2937[/ATTACH]
Mike can you tell me where the build date is? I went to buy a new MAP and was told I need the build date.:neutral:
I would like to update everyone on map problem, BUT UPS screwedup and didn't delevery my new one yet:banghead: so will update when ups lets me have my order. Truck runs fine just Scangauge reads only 8.5# of boost. It stopped throwing the code so thats a good thing.:)
Well that's a bummer.:banghead: Yesterday the scangauge was showing 14.3 at idle and 23.6 at WOT. Here I was thinking MAP was working.:duh: Looks like I will have to buy a boost gauge after all:duh:
Got my new MAP installed. Since I don't have boost gauge:banghead: I just have to go by the scangauge which shows 13.8 at idle 23.6 at WOT. Maybe it's just me but truck feels like it is running better. Boost gauge is my next wish list item. Thanks for all the help on this site.
