- Replies 13
- Views 14.8k
ISX 5 posts
mr.mindless 3 posts
flagmanruss 2 posts
dripley 2 posts
I decided to get rid of every single regular 6 point bolt and put stainless allenheads there instead, maybe regular 12.9 grade allenheads as well, I love allen bolts
. Figured out it wouldn't cost me but $50 to do the whole engine. Some bolts have rusted and I want them out of there as well as getting some good antisieze to put on every single bolt. As a side effect, I will be making a list of every single bolt size on the truck. I still have to do some counting and I think the timing cover has 2 different sizes but I couldn't remember which one I needed to pull out that was the other size so I gotta go out and keep playing with it. Here is what I got so far. When you buy these bolts, they will be using the same units as the threads, as in since all of these are metric, the length you need will be in mm as well. If for some reason you need to convert the length to inches, just take mm / 25.4, to convert back to mm, take inches x 25.4.
This thing resizes it automatically so if it is too small or I guess it is even a little blurry, here is the original format.
