- Replies 7
- Views 3k
Mopar1973Man 3 posts
charro 3 posts
dripley 1 post
Good Morning Everybody,About 4 days ago i was driving and got a check engine light, did the 3 key on procedure and found code P1693 then the check engine light was gone, went to mechanic hooked obdII scanner and found no codes. Driving back home when i got to a stop sign i exprerienced "dead pedal" and got check engine light again, and drove home at idle speed and sometimes after a few blocks it came back to normal. I hooked obd II scanner and got code "P0223" THROTTLE PEDAL POSITION SENSOR/SWITCH B CIRCUIT HIGH. I went ahead and ordered TIMBO apps sensor, received yesterday and did the voltage adjustment, started the truck and drove it for about 15 miles and was working fine and accelerating perfect and no slack. When i got home and was parking at the driveway the check engine light came back on and again i had dead pedal. Did another scan and got the same code, started the truck and it accelerates again, could it be something else besides the sensor?I did the test for DTC P0223 i found in this website and the results are as follow:Step 1. Voltage at terminal 6 brown/orange wire on apps connector is at 4.72 volts.Step 4. Voltage at terminal 2 light green/dark blue wire on apps connector is at 4.72 volts.Step 7. Resistance at terminal 4 black/yellow wire on apps connector is at 00.6 ohms. It says that if less than 5 ohms to replace apps sensor. Could it be that TIMBO sensor is bad?
