44RE woes: gear engagement issues...
- Replies 18
- Views 8.6k
Rogan 9 posts
ramhunter9 7 posts
Mopar1973Man 2 posts
1997 Jeep Grand Cherokee Ltd., 5.2L, 44RE, NVG249, 155K on the odo.Replaced trans, TC, radiator, cooler, on 9/9/09, @ 118K due to slipping badly; band adjustment performed prior to replacement (no change.)Fast forward to current time:Cold starts, Reverse and Drive (1st) engagements are slow and inconsistent. Once warmed up, engagements are normal and without fault. No codes. Fluid level is optimum. Aamco says it needs rebuilt. I think it's a fluid issue: either the pump is weak, or there is a drain-back issue somewhere, causing the trans or TC to lose fluid to the pan, causing pressure to drop.Any ideas? I don't think a band adjustment is the answer, as it doesn't slip; acts like it just doesn't want to engage the gear when cold (below operating temp.)
