Timing Effects
I took the P7100 out a while back and I got in a hurry and messed up the timing but it ran fine so I said heck with it. I noticed it started up basically instantly, but quickly fell on it's face. When I pulled our trailer the same place (Branson), instead of the usual 15-20psi max, I was now getting into the 30's and it still didn't have the same power. I found it interesting so I drove it some more, pulled some more and now I got a chance to see exactly what the timing was. Believe it or not, it was at 3.8* :stuned:This was actually good because it really made the effects show. Starting is a lot quicker of course, because the piston gets a chance to go up farther, building more heat before the fuel gets shot in. It was 44F a couple days ago and it was still starting insanely fast and my grids are not hooked up. It actually seemed to be doggier at low RPM driving than usual. You would think it would be better off but it really didn't show that effect at all. Higher in the RPM it was a piece of crap. It still had power I suppose but it was nothing to brag about and definitely didn't snap your neck. Boost has just been wayyyy up there trying to compensate for the crappy fuel burn. Mileage was somewhat worse, but I still got 15mpg pulling the trailer 70mph, which is 2100 RPM. It was very obvious that I was stepping on the pedal a lot more. When you floored it, it really was a junker. Mine being a 215 pump means it has retarding notches to allow more fuel in, which I am told allow up to 4* retarding. Which means it was dumping the fuel in right at TDC. It smoked a lot more at all RPM's.
  • Replies 128
  • Views 71.9k
Those NOX output numbers are probably at rated rpm, not at idle. The injector/piston relationship could also factor into the sound at idle on the 24V.Once UDC is released for the VP trucks we can get a good look at it's timing. On the CR trucks they idle right around -4° on the main event.
I know it's at rated RPM. But they are noisy at any RPM. I used to drive a 2002 6spd at work and I would short shift it just so I wouldn't have to listen to it. If the CR is that retarded then that makes perfect sense as to why they are so quiet. Mine was really quiet when the timing was really retarded. What is this UDC thing?
Yeah 24V's are noisy, but I think they are just as noisy with a P-pump conversion. www.madselectronics.com Yeah with the retarded main and the pilot it makes for a very quiet motor, and super easy starting.
I never thought of that! Time to go to the big forums and ask them. :hyper:
I recall seeing a list of what advance/retard timing does and if I recall correctly, advancing timing creates more NOx, but less particulate matter. When you retard, it does the inverse. Being as the engineers that were coming up with the VP system were probably doing this in 1997 or so, maybe particulate matter was the devil back then. It seems as though NOx emissions are a relatively new concern. I don't remember hearing anything about NOx before about 2006 really. If the engineers were trying to minimize PM rather than NOx, that might explain the crazy timing.
Well this took a weird turn. http://www.cumminsforum.com/forum/98-5-02-24v-p-pump-conversion/475540-24v-knock-ppumped-24v.html Basically they said it's the VP making all the racket. That makes a lot more sense than the insanely advanced timing that it sounds like. Also explains why the 2 stroke makes it a lot quieter though I have yet to hear a 24V with it in it in person. Hmmmmmmmm how the tables have turned.
I don't know what their deal is but at least I got my answer. But then again the 24v sounds like a truck that's running 24* haha. That's why I think the pump making noise is a very logical culprit.
Good information. I have only heard one 24V P-Pump, think he had about 14-15°, but I thought it sounded like a 24V, but I have only heard 1, and don't spend a ton of time around 12Vs or 24Vs.
I could really tell my 12v from my friend's 24v when we would park next to each other idling, I don't think I've done that since the 24v went in my truck. Back then I really just thought it sounded like twice as many things going on and I blamed the valve train. Not sure if that's still the case or not... I'll make a mental note to check next time we're running together and pull up for fuel next to each other again.
I still think it is timing rattle. If it were the mechanics of the VP making the noise, why would it get quieter when it's hot outside and it's up to operating temp? I think the guys with the P-pumped 24v's are not good comparisons because there are so many different variables (i.e. cetane rating, pop pressure, injector hole sizing and quantity, inj line diameter, DV size) that can all change "EFFECTIVE" timing. One guy can say he's got 24 degrees timing, but the flame front could be totally different than another guy with 24 degrees depending on the setup. 2 stroke - I also noticed a major difference in sound when I add 2 stroke oil to my diesel. I think it has very little to do with lubing the mechanics, but MUCH more to do with effectively retarding the timing. 2 stroke oil is more resistant to compression ignition than diesel. Adding two stroke oil moves more of the ignition pressure peak ATDC and lengthens the entire combustion event (and smooths the peak) which decreases the "knock" that we all hear from the 24v. Same reason why WVO and WMO all quiet the motor down. Adding a slower burning fuel to the mix creates an injection event similar to what they were trying to acheive with the common rail: small fire at first, medium fire in the middle, small fire at the end to decrease any PEAK pressures and quiet the motor significantly.
ISX:When you had your timing seriously retarded, how did the motor sound? Did it quiet way down and sound real smooth at idle?
Ohhhh yeah. Started up before the sound hit my ear as well.
That's what I thought. I bet that you could make a 12v sound much like a 24v at idle if you advanced timing to about 30 degrees. Also, I bet you could make a 24v start on a dime and idle extremely smooth if you retarded timing to about 3 degrees at idle. This further makes my point that the noise associated with the 24v is a matter of building too much in-cylinder pressure BTDC, from having timing way too advanced.
But if it already way too advanced, why does the edge chip advance it even more?
To be honest with you, I don't know why anybody would run a programmer/box that advances timing. I have the Super X VP44 that comes with "timing advance" from the factory and I kinda regret it. It's a good pump and it makes real good power, but I think the power comes from higher injection pressure rather than timing advance. When I had my Edge Comp (timing box) hooked up, it made a whole lot of black smoke, but never produced much power until I hit about 2300 rpm. That's because timing was just way too advanced. I want my power from 800 rpm to 2000 rpm, where I can take advantage of it towing and on the street. If you use a Cummins like it was meant to be run, it shouldn't need any timing advance. I'm talkin never go over 2100 rpm. It's not until you get into the 2,000+ rpm that timing advance helps make any power. That doesn't do me much good with a trailer in tow, or just stop light to stop light. We've all drank the koolaid that advancing timing somehow increases low end torque, when the truth is, it hurts low end torque. The only difference at low RPM that you feel is from added fuel, rather than added timing.
A lot really depends on what truck, it's use, and how it was setup. Most timing has been done for emissions, and even the static timed P7100 was partially for emissions. The VP and CR use dynamic timing, which is for emissions and drive-ability. The dynamic timing allows for better starting, improved economy, and a flat torque curve. But in general I don't think anything would hurt from a little timing, heck I gained up to 55hp/100ft/lbs from 1600-2400 from timing along, and the motor is more responsive, smoother, and more efficient. Timing is good!
Well, I could see where the CR motors might could use a little timing advance, especially since they're so strapped with emissions tuning. They probably came from the factory with timing too retarded anyways. On the VP motors, we've already asserted that it's too much timing that's making the rattle, meaning that we probably have more than enough anyways. I agree, it's all about the entire vehicle setup. Little things like gear ratios could dictate where the sweetest spot for timing is. I think we can all agree that the VP motors have too much timing advance on idle... timing programmers will only make that worse (if they add any timing at idle).
I thought the guys with P-pumped 24V's and 24° of timing don't have the rattle, and thats a LOT of timing, I don't think that the VP trucks have more than that at idle. I can't find it right now, but Michael has a chart that shows the timing vs rpm vs temp. I agree that just adding a static addition isn't the best, but a dynamic addition is good, even on a VP truck, just not too much.
24 degrees of timing on a P-pumped 24v probably isn't that much if you have injector pops set at 310bar. I would still like to hear a a p-pumped 24v running that kind of timing with 260bar injectors. I would venture to say you could make it sound exactly like the VP'd motor if you kept advancing that timing...As for the programmers that advance timing, I would be interested to see if they actually add timing progressively like you're eluding to. It would make sense, being as the 24v with Edge doesn't idle much differently than 24v without, but I'm not sure that most programmers are sophisticated enough to do that. It seemed to me like (on my '07 CR) the Quadzilla XZT or whatever it was, made the idle a little louder, which I attributed also to extra "static" timing advance.I too have seen the chart with timing vs boost vs RPM, but unfortunately the numbers are never legible no matter whose version I see of it. That's sad... because it might could put all our debate to rest.
