I took the P7100 out a while back and I got in a hurry and messed up the timing but it ran fine so I said heck with it. I noticed it started up basically instantly, but quickly fell on it's face. When I pulled our trailer the same place (Branson), instead of the usual 15-20psi max, I was now getting into the 30's and it still didn't have the same power. I found it interesting so I drove it some more, pulled some more and now I got a chance to see exactly what the timing was. Believe it or not, it was at 3.8* :stuned:This was actually good because it really made the effects show. Starting is a lot quicker of course, because the piston gets a chance to go up farther, building more heat before the fuel gets shot in. It was 44F a couple days ago and it was still starting insanely fast and my grids are not hooked up. It actually seemed to be doggier at low RPM driving than usual. You would think it would be better off but it really didn't show that effect at all. Higher in the RPM it was a piece of crap. It still had power I suppose but it was nothing to brag about and definitely didn't snap your neck. Boost has just been wayyyy up there trying to compensate for the crappy fuel burn. Mileage was somewhat worse, but I still got 15mpg pulling the trailer 70mph, which is 2100 RPM. It was very obvious that I was stepping on the pedal a lot more. When you floored it, it really was a junker. Mine being a 215 pump means it has retarding notches to allow more fuel in, which I am told allow up to 4* retarding. Which means it was dumping the fuel in right at TDC. It smoked a lot more at all RPM's.
  • Replies 128
  • Views 63.4k
The XZT and Edge are not programmers, they are modules. But the Edge could be dynamic, the XZT would be less dynamic as all it does is effect the MAP signal, whereas the Edge plugs into the injectors. Here is a screen shot of some Smarty timing on a CR, I think a 03-04, as you can see it's quite dynamic. Blue is stock, pink is modified. It's a 3D map, so hard to get a single shot that shows it all, but this is pretty good I think.
Both of your guys' posts were great. Still makes me wonder where all the knocking comes from on a VP44. Another weird thing is on my 215 pump there are retarding notches when you are at WOT. Some have said that's for packing more fuel in but I am thinking it must be an emissions thing. It retards it 4* from what I have heard.
It could also because with the added pressure of WOT and rpms you get more timing advance thru quicker ignition from the improved atomization.
You're gonna have to expand on this so I can wrap my head around why you think this way. Not doubting I just want to see it in the same light as you.
As you increase rpms the pressure out of the P7100 increases, as the pressure increases you "advance" timing by two ways. One is the pressure hit's the pop pressure sooner and thus injects sooner, and the higher pressure atomizes better and flows faster (so more, easier to combust, fuel is injected sooner than at low rpms) and the fuel ignites faster. Both of those have an advancing effect on the actual ignition timing, even if the P7100 stayed completely static.
I had to really think about it to grasp that :lol: I don't know how much difference it makes but I am thinking it really wouldn't do much more than a degree or 2, if that. But then again, I am not sure. The higher flow from the plungers going faster would just raise the pressure at the bottlenecks since at a constant plunger position they are going to pump the same amount of fuel regardless of RPM. This means at higher RPM it would be shoving the fuel through the bottlenecks like the delivery valves at higher pressure but the injector is going to pop the same amount of times as at low RPM (same plunger position) per piston stroke. I would like to think it advances but I am just not sure. Seems the laws of hydraulics would keep everything relatively the same. I will think more about this though.
If you delve into the common rail world you will find some more conversations on the topic. Same theory applies, fuel injected at 18K psi will ignite sooner than fuel injected at 10K psi. The P7100 is capable of 18,855 psi. Remember we are talking about the initial ignition point, not total fuel pumped. On a mechanical pump the pressure probably has a very little effect on total fuel, but it will still have some effect as you will spend a greater time above pop pressure.
Now I'm captivated. My injector says 260 bar which is 3771 psi. Are you saying that the plunger can jam 18,855psi out the delivery valve if it needs to and hence the injector sees that much at times? I would think that means the injector would be popping insanely fast rather than what I see on a pop tester lol. What can the VP44 pump out then?
That's the max pressure a Bosch white paper had, not sure what it does under normal driving or WOT. The VP44 is capable of approx 17,400 psi. CP3 in 03-07 is programmed to 23,106.
Boost, more often than not, also increases as RPM increases, which would additionally advance effective timing. So to get back to our VP-44 conundrum... what is it that makes the VP burn more fuel when it's cold. Obviously it's something computer controlled, so what all parameters can the VP-44 control/manipulate to make power? 1 - Timing Advance/Retard 2 - Event duration 3 - Injection Pressure? How does the VP vary the amount of fuel injected if not by duration? Pressure?
Basically pressure and timing that it comes down too... Because duration is a factor of injector size so larger injectors have a shorter duration with the same pressure. Of course reverse than and have a stock or smaller injector and it takes a longer duration to inject the same amount of pressure. Because the injectors open up after 4,500 PSI roughly and start injecting fuel till the pressure falls below 4,500 again. To be real about it the pressure actually goes up and down on the injectors (called chattering)...What am I saying here... :banghead:
Of course reverse than and have a stock or smaller injector and it takes a longer duration to inject the same quantity of fuel.
With the pump stroke, you're dealing with injecting a fixed volume of fuel (in a given circumstance) and varying pressure and rate with pump type and injector size, so it will take a longer or shorter duration to get that fixed quantity through the nozzle based on the volume the injector can pass.
That makes me wonder if there is a point where you can put too much fuel to it. If I do enough rack mods to get full rack travel and I get the fuel pressure to run at 50psi, is it possible that when I am WOT that it would try to shove so much fuel out of the stock injector, that the pressure rise would get to the point that the injector cracks or the injector lines burst? Seems possible. I have another thing to start a thread on that has to do with duration that will be very intersting to discuss.
duration is a very important component of timing that seems to be ignored in most corners of the Cummins world. well studied in TDI circles - where smaller things make changes more apparent I'd expect. Same requested injected quantity through a bigger hole gives less smoke and lower EGTs because more of the fuel is shoved through the hole sooner giving a shorter ignition event and more accurate timing.
Supposedly on the 1st Gen's it possible to rupture a injector line with a VE pump turned up too far. I've never seen it but heard of such happening. If its true or not I'm not sure. :shrug:
Ah so it is possible. Probably hard to ever get to that breaking point. I think there is a fine line between optimum duration and optimum atomization. If you get a big injector, the duration will be short but the atomization won't be as good. Get a small injector and the atomization is good but the duration is long. Everyone seems to gain mileage with those RV275's so I am betting the duration was too long on the smaller injectors.
Once you get to about +75 HP (and above) injector then the MPG are neutral again from stock so now the duration is too short and atomization is poor. I'm not saying this is the case with everyone just saying general rule here... :whistle:
It's about the same on a HPCR. 50's provide an increase, 90's no change, and 90+ a decrease... again as a generalization.
So the OEM injectors are too small. Actually it's kinda interesting. I don't know how big the 24V injector is but I would assume mine would be smaller. I get great mileage so it's weird how you guys going to a bigger injector get better mileage when the OEM was already bigger than mine to begin with. It's things like that that drive me nuts. I know the engines are slightly different but stuff just never adds up and unless we buy a million dollar machine to see exactly what happens then I will never be satisfied :ahhh: We can assume stuff all day though the clues might get us closer to the real truth. I just wish there were more clues, but I am getting sooo close to finding the truth to it all.
