Baldwin question
I am going to try bf 1212. I see that the rubber gasket is shorter than the fleetguards. Is the filter housing machined different ?
  • Replies 5
  • Views 2.1k
What housing does the 1212 fit? Or does it fit a AD 150?
I have a fass 150. When i change it i will post a picture of the rubber washer.
I would guess the housings are slightly different. Just use the one that came with the Baldwin and it will be fine.
Yes, the baldwin filter top is machined with a cone type compared to the flat top fleetguard. The little rubber gaskets are vary close in size. The 1212 fit perfect. I feel better with the baldwin, winters comming. My next move is the fuel filter.Is the donaldson p569381 the same as the hf6604 ?
