Front Drive shaft Question on 4x4
- Replies 13
- Views 4.7k
Rick C in Oakville 6 posts
ISX 4 posts
cummins2k 1 post
dually 1 post
Having taken out the front drive shaft to change the clutch, I noticed that there is a rubber cover over what looks like a joint in the front driveshaft. Is this suppose to slide to take up changes in the suspension movement? If so mine must be seized, as it feels like one solid drive shaft. Anyone unseize one of these before? I have it out as I need to change 1 seized Ujoint at the Cardan joint, so a good time to correct this if so.ThanksRick
