- Replies 34
- Views 15.9k
texas503 14 posts
ISX 12 posts
Mopar1973Man 4 posts
MnTom 2 posts
I recently bought a 1997 auto Dodge cummins with #0 fuel plate full back, AFC full back (towards cab) 3000 GSK and 15* of timing. I have tweaked on the star wheel a little bit. My question is I have a 1999 24valve cummins auto with RV 275 injectors that has alot more low end power than this 12 valve. Is this normal? The 12 valve will run off and leave the 12 valve in upper RPM's but not down low. Is this normal due to variable timing and slightly larger injectors of the 24 valve? My 24 valve would really light the turbo at about 1200 rpm but the 12 valve won't until about 1600 rpm.So far the 24 valve is the better tow rig just because of low end grunt. Any suggestions?
