I took the plunge, and got the comp, before i install, i have a quick question. What color is the pump wire, as i didnt get the bd cover at this time, instructions say wire at the top, does not state color of wire to hook grey wire to.Thanks in advance guys.
  • Replies 15
  • Views 4.8k
Ok that makes it fun, says to use wire closes to block, im sure they will be side by side and i want to choose the correct one, i guess there is no answer, can you tell me if damage will result if the wrong wire is tapped? Thank you for the diagram though, i appreciate it.
From what I know is the wrong wire is tapped it does nothing...But if the right wire is tapped it got more power...But now if the wrong wire is tapped and the wire is left exposed to weather then you might take on pump damage. I would suggest to hold out for a stealth plate so there is no guessing.
Ok i did, 61 bucks not bad, coming out of Washington so it shouldn't take long. Thanks
That's the only draw back to the Edge Comp, tapping the wire.Are there any plug & play diesel programmers?Thanks & good luck,Dave
That's the only draw back to the Edge Comp, tapping the wire. Are there any plug & play diesel programmers? Thanks & good luck, Dave
All plug N Play addons are limited to 60-65 HP period... All VP44 tapped modules are limited to roughly 150 HP... Since the wire tapped modules are after the ECM they get final say in the signal sent to the VP44 but in the cause of programmers they have to play by the rules of the ECM hence why the limits are much lower.
I think all fueling boxes tap the pump. programmers are timing and duration boxes i believe. i have a edge EZ im gonna sell when i install comp, its a timing and fuel duration box with no tap, 65hp 180torque.
If it will work on a my year, I'm up for it! Please send me a PM when your ready. Thanks, Dave
I do not believe it will, the connectors are different, the one i have is for 2000 and 2001. sry would love to sell it to ya.
That makes sense. So with the tapped wire it's like having a Hot Rod vp44 version.:pant:
Dave
Crap, the story of my life it seems sometimes.
I'd love to have it, I was thinking about that all last night!
Thanks,
Dave
Dave
HRVP44 is roughly +40 HP... Edge Comp tapped is +120 HP so it like have 3x time the amount of power of a HRVP44... Now but a untapped Edge Comp is the same power of a HRVP44 +40 HP...
Nothing will happen if you tap the wrong wire, my friend I had helped me and tapped the wrong wire. I tapped the right wire and dabbed a little silicone on the other one and all has been good. The wire that needs to be tapped is the top wire, if you look on the edge site at the instructions for the juice its got good pictures but the comp pictures are horrible.
Thanks for educating me!:smart: Dave
