NV4500 grinds going into second
- Replies 6
- Views 5.7k
Rogan 3 posts
moostang 1 post
jonathan1950 1 post
MarbleCrusher 1 post
So I will need to tear apart my NV4500 and replace the syncros because it grinds when I shift into second gear. If I double clutch then I can shift with out grinding gears, but trying to down shift is difficult, so I am planning on tearing it down to replace the syncros, just wondering if I should have any other parts handy to replace since it is opened up? It seems to be fine otherwise, no whining, the gear shifter is tight and it does not seem to leak any fluids. I do not know if it has the fifth gear fix or not? Thanks for any insight.
