- Replies 9
- Views 3.4k
Dave3500 5 posts
Mopar1973Man 2 posts
dorkweed 1 post
cummins2k 1 post
Hi guys,Because of Michael's recommendation I went ahead & purchased a used canister, bracket & filter from Ebay. I need some info on what fittings to buy from the Frantz site. Michael, you used to have a picture of the return line going through the oil cap. I think I'd like to use the same. Any problems with that for you? What do I need for that? Also, I read on one of your postings that you used an outlet from the factory filter mount, what do I need for that?Is it less messy to change the filter with the lines on the top. Is that why you did it that way? I only have about 1,500 miles on this oil, I think I'm going just install it when I get my parts together. I know Frants has an install kit but I won't be needing all those fittings.Thanks,Dave
