injectors
hello, newbie and first posti took my injectors out and sent them in and had them pop tested 3 came back good and the other 3 came back bad sticking nozzels,,,Can nozzels stick?i pulled the three bad ones apart just as one of your post shows and nothing was sticking so what do they mean?can this be true?
  • Replies 4
  • Views 2.3k
Dirt and debris... Same thing that was wrong with my RV275 I got from CajFlynn they seen over 400K miles of roads. But they just didn't work to good for me. I took them apart and clean them up and everything works good now...
Injector Cleaning
i took them apart and cleaned them behind the shop,so if everything moves free inside the nozzels everything is fine?
Measure the pintles and the bore and be sure they are fitting properly... Like mine where gummed up with coked fuel and the pintle needles where about 1/2 thousandth tight. After cleaning then they fit good and smooth again.Might also look into your fuel filter and the media your using I aim for a 2-3 micron filter. Using either a Fleetguard or a Donaldson filter.
