Hi Michael and members,
It's been awhile since I have posted on here, nice changes to the site, it looks very good. Anyhow, I thought I would share my experience with this product,
http://evergreen.cagehosting.com/index.cfm/products/ar6000/ar6200-combustion-catalyst-and-burn-modifier/
in a nutshell, it will make any truck run like the best tank of fuel you have ever run. I came across this product by accident, and its formulation is really nothing new, but requires very little to produce big results. It basically brings our low quality ulsd fuel up to spec. I came across it when ordering some AR9100 friction modifier from this company, they sent me some samples of the AR6200, and after adding 1oz to my tank, the difference in low end performance and the way the truck ran was literally mind blowing. Another positive effect is the way it runs when cold starting, it will start and run like it's already warmed up. I am not alone in these results, as I ended up giving samples to neighbors and coworkers with Cummins/Dmax's/Powerstrokes, the results were the same across the board, all wanted more. Once in the trucks system, you really only need no more than an 1/2 ounce to treat a tankful, and it can be used with 2cycle or other additives. Nothing I have ever ran in my 03' 6L Powerstroke has made it run like this stuff does, it really does work that well. It makes one realize how low quality our fuel is today, this product is very addicting.
Harry
Hi Michael and members, It's been awhile since I have posted on here, nice changes to the site, it looks very good. Anyhow, I thought I would share my experience with this product, http://evergreen.cagehosting.com/index.cfm/products/ar6000/ar6200-combustion-catalyst-and-burn-modifier/ in a nutshell, it will make any truck run like the best tank of fuel you have ever run. I came across this product by accident, and its formulation is really nothing new, but requires very little to produce big results. It basically brings our low quality ulsd fuel up to spec. I came across it when ordering some AR9100 friction modifier from this company, they sent me some samples of the AR6200, and after adding 1oz to my tank, the difference in low end performance and the way the truck ran was literally mind blowing. Another positive effect is the way it runs when cold starting, it will start and run like it's already warmed up. I am not alone in these results, as I ended up giving samples to neighbors and coworkers with Cummins/Dmax's/Powerstrokes, the results were the same across the board, all wanted more. Once in the trucks system, you really only need no more than an 1/2 ounce to treat a tankful, and it can be used with 2cycle or other additives. Nothing I have ever ran in my 03' 6L Powerstroke has made it run like this stuff does, it really does work that well. It makes one realize how low quality our fuel is today, this product is very addicting. Harry
