Early shifting and surging??
- Replies 20
- Views 6.4k
nkruse 7 posts
Mopar1973Man 4 posts
2500ctd 3 posts
pepsi71ocean 3 posts
Hi guys. I have a couple questions on what is going on with my truck. I noticed I am shifting too early where the RPM's are low and it surges or jerks until the RPM's get higher. It is shifting into 4th gear with OD off at 25mph and it happens also about 45mph where its shifting into high gear and doing the same thing with OD on. Tonight I was doing a couple road tests and I got on it alittle more than usual and when I got home because of how it was acting, I used my scangauge and I had a p0234 code. So I have been doing alittle reading about the wastegate etc which I do not understand and wonder how the code is related to what is going on with my truck. Is it something else with these symptoms??? The only thing I have done different recently is have an Airdog 100 installed and hooked my Quadzilla XZT up a month ago. Any suggestions or answers are appreciated!!
