- Replies 88
- Views 12.8k
flagmanruss 43 posts
MnTom 29 posts
Mopar1973Man 5 posts
Ilikeoldfords 4 posts
I bought this trailer to transport my mobility scooter... been shopping & burning fuel (misleading ads... hating the lieing SOBs! Did they think I wouldn't see the rust?) So this one was cheap, $200... because the seller honestly stated it needed work. It has a drop in plank at the rear, no ramp, tilt trailer.
When I arrived, he had his compressor out but couldn't get one tire to hold air... dry rotted anyway... so I bought 2 New tire/wheel assemblies at Harbor Freight $105 & he put them on. Trailer lights were there but not working... I high-tailed it. Near an hour drive, highway through major urban area... tried to use the truck signals & leave enough room & did not make the aquaintance of any fine LEOs.
I did not think to take the set of spare trailer lights I made up to move a covered wagon some years ago... (the wagon's fitted trailer had been hidden in a pasture & I knew better than bother with the lights at the last minute... why did I not remember?) I'll rewire the trailer with plastic conduit while the deck is off.
Most of the rotted deck was still there when I arrived home. Rotted plywood over the rotted & termite eaten planks... I optomistically stopped at Home Depot & bought new PT planks. I have some green cuperinol & I'll give the decking some additional treatment before installing.
The trailer after...
I brushed & scraped the rotted wood out of the channels. There is some scaling that was hidden by the wood... everything exposed is good. I'm thinking the sides add a lot of strength to the trailer. I'm thinking the hidden areas might be a good place to learn about POR15. The exposed areas probably just use paint.
The decking minutes later...
Notice my little plastic stool, a place to sit... My legs were pretty done, so I cleaned up my tools for the day.
I'll have to grind the welds off the strap that hold the planks down... I wonder if I should have it welded back or bolt it down? The latest PT is not as good as before & I'm concerned that the holes might be a place for rot to start... but bolted through with carriage bolts would make servicing much easier for me.
Well, here's todays picts.
