Fuel Pressure Gauge Keeps Going Crazy
- Replies 6
- Views 4.3k
Mopar1973Man 2 posts
cumminspower 2 posts
dorkweed 1 post
Cummins2001 1 post
Hi Everybody.....I'm new to this forum. I found your website while I was looking for information on the web for a weatherhead needle valve for my fuel line.........Looks like a great website & forumI'm having some problems with my fuel pressure gauge...I recently installed a new ISSPRO electronic fuel pressure gauge & Vulcan universal fuel line on my truck. I have the fuel line attatched to the test port on the VP-44. Everything seemed to work fine at first after I got the gauge installed. The fuel pressure readings stayed constant (14-15psi at idle) & fairly constant when driving. After about 3 times driving the truck the fuel pressure gauge started going crazy & bouncing all around between 10psi - 20psi constantly. I pulled the sending unit off of the Vulcan fuel line & made sure to bleed all the air out of the line & put it all back together. After a couple more times driving the truck & shutting it down for an hour or so it starts doing the same thing......I'm not too sure what's going on.....It seems to have something to do with air getting in the line but I'm not sure.....Anyboody else had any problems like this after installing their fuel pressure gauges...Thanks for any help or suggestions..
