Hey guys, just wondering what boost readings you all are getting when using scangauge 2, and edge comp, i get like 14psi boost showing on scangauge after changing map sensor with a genos garage unit, old one read .-0.7 at idl, and would track slightly behind actual shown on isspro gauge, new one tops out at 22psi on scangauge.Thanks
