- Replies 8
- Views 1.8k
JOHNFAK 3 posts
rooster4473 3 posts
Mopar1973Man 1 post
hex0rz 1 post
My trucks has been shifting funny, last night I thought it was going in and out of OD to drive. Today it seemed ok when i was just driving it normally around normally, but i was messing with shifting it on a flat streach of road and if I turn off the OD i can tell it goes into drive, but if i manually put it into 2nd itll rev for a second and then its like being in neutral, but if i manually put it into first I can tell it drops into first and revs. And its the same starting from a stop. If i put the truck manually into first and pull out i can tell its in first, then if i shift to second its like hitting neutral, and then when i manually put it into drive you can tell it goes into drive and then od. I scanned it and its not pulling any codes up. So is my 2nd gear fried and i need the tranny rebuilt or could it be a computer issue but not have a code.
