Mix ratio for 2 cycle Oil
- Replies 18
- Views 10.4k
Mopar1973Man 5 posts
dorkweed 3 posts
flagmanruss 3 posts
keydl 1 post
The easiest way to remember mix ratio for 2 cycle oil for your truck is 1 ounce of oil for every gallon of fuel. So basically if you put 20 gallons of fuel in you need 20 ounces of oil. This will work out to about 128:1 ratio which is very safe to use! Just for information purpose. Cummins authorizes up to 5% of WEO (waste engine oil) to be blended into diesel fuel. Knowing this now you can add up to 1.75 gallons of 2 cycle oil for a 35 gallon tank. But I would only stick to using 2 cycle oil and mixing 1 oz of oil to 1 gallon of fuel...
