- Replies 7
- Views 2.5k
Jnance 3 posts
Mopar1973Man 2 posts
AH64ID 1 post
white01 1 post
I'm having troubles with my truck, I can't get it started right now. So I'm trying to go through a do some trouble shooting. One code though the truck is throwing is a P0193, I got a rail pressure gauge in the mail today ,but it hooks up electronically too so that not a lot of help. I was just going to replace the sensor, but what has thrown me off is that I hooked up the electronic rail pressure sensor and it pegs out, which makes sense because the truck says its reading high too. But when I unplug the harness from the sensor then try and crank the truck the gauge still pegs out. I would think it should just read 0, since its not hooked up to the sensor. which this kinda makes me believe something might be shorted before it gets to the sensor? Whats your guys thoughts? Thanks
