Have re-routed my CCV as in Mopar's pictures on Thread. i am getting a oil mist spray under trans & frame whats up with this?, Funny thing is it use's no oil between changes that i can tell. MOPAR TO THE RESCUE!
  • Replies 7
  • Views 2.5k
The oil vapor exiting the tube can condense causing a fine mist. There would most likely be an un-noticable loss in oil.
We talked on the phone for quite a while... I think that cummins2k is right for the most part... As long as your not using oil between oil changes and the oil is just a mist your fine. Like my own truck leaves just a bit of splatter on the bellhousing.
Hey Thanks Cummins 2K & Michael.
Edited by rburks
forgot to put my thumbs up
Well here is an Update to my oil spray issue I thought was comming from the CCV Tube. As it turns out most of it is comming form the CCV filter vent Housing. OK this problem stems back 2-months ago when i installed new injection pump, this is when i done the CCV design mod. from Michael's thread on Website. When I reinstalled the CCV Housing i noticed that when i tightened it to the original location {to where the stem for the hose connection was turned straight up} that it was not tight at all. when i would turn it to where it was snug the stem would be at 2:00 aclock position where i could not connect my vent hose. Yesterday i found where the oil was seeping from the bottom side of CCV housing, dripping down front cover where the fan was blowing it, "well you know the rest of the story, ALL OVER THE BOTTOM OF THE TRUCK" Now, in all my unique wisdom LOL, I desided i could tighten it a full 360 degree turn back to where the stem would be straight up. "DO I NEED TO TELL YOU ALL WHAT HAPPEN NEXT" I did not think so LOL. DOES ANYONE HAVE A CCV VENT THERE NOT USING
Edited by rburks
mis-spelled a word
There should be a o-ring on the vent cover did you try to replace that? Maybe its just all crushed down to the point it won't seal at straight up and down... :confused:
Think of it as free undercarriage rust and corrosion protection and prevention. :O)
:lmao2: I always thougt of it the same way... But when your marking your driveway and leaving a trail of oil I think it time to look into the blow-by issue.
