- Replies 6
- Views 2.4k
dave110 3 posts
Mopar1973Man 2 posts
Rogan 1 post
Hi all! I have an issue thats been bothering me. Every now and then my ABS will activate. At first I thought I hit loose stones or an oil patch but that's not the case. Does it pulling a trailer or not and I switched to a new brake controller that's supposed to be ABS friendly. Sometimes I can make it happen by pushing very lightly on the pedal. If I push hard on the pedal it will go away. It only seems to do it at the very begining of the pedal travel when I push down lightly. I'm thinking the sensor in the rear axle but during my search it seems the speedometer usually goes wacko if that goes bad. My speedometer is fine. Anyone have any ideas? :shrug:Thanks
