- Replies 12
- Views 7.9k
fire176969 6 posts
rancherman 3 posts
Haggar 2 posts
Mopar1973Man 1 post
I recently had to replace my steering box due to a broken output shaft. Put a upgraded Borgeson steering box on the truck that I got used for a good price. Worked fine on the truck it came off of. Ever since the brake pedal has been really hard to push initially, then when it gets past the hard spot in the pedal, the brakes seem to almost lock up and toss you into the dash. The steering assist is almost non existant at idle. The assist goes away completely when using the brakes. Steering acts completely normal driving down the road but the brake problem is still present. Just installed a new Borgeson power steering pump on to replace the old one per their recommendation. No air in the system, currently waiting on a return e-mail/phone call from Borgeson and thought I would see if anyone else has ran into this issue before.
