- Replies 8
- Views 2.7k
Mopar1973Man 3 posts
Howie67 2 posts
Eforbes 1 post
Ilikeoldfords 1 post
Ok so i did the vent relocation mod shortly after i got my truck a couple of years ago, and cleaned the mess out of the radiator. Where the tube exits is just above the front diff/ujoint. It pushes enough oil out of the pipe to completely drench my u joint and drip on the ground. I have seen some videos and it seems this is excessive. :think:I also have a headgasket leaking externally so i figured no need to just go part way. I am saving for a overhaul now.
Just wanted to double check the obvious. :banghead:
