- Replies 6
- Views 8.9k
Haggar 3 posts
Rwilson 2 posts
Mopar1973Man 1 post
Hello all, I'm new to the site/forum and thought I would introduce myself and get right in to the mix.My name is Ron, I'm from CA, and I love to put cummins motors in trucks they didn't belong in.I have a complete donor 2001 cummins 24 valve. I actually have the whole truck. I put the engine,trans, and transfer case in a 2001 Chevy 3500HD. My question is, im doing the wiring right now and I have the truck runningbut i have absolutely no throttle at all. idle only. im wiring from the c130 connector and im using the factory ecm and pcm for the 24v. i have a light green/black wire that in my schematic needs 12v in start run position. But when I hook it up to switched power the truck turns over but doesnt run. if i leave the wire disconnected it fires right up runs. as soon as i touch the wire to the switched source while its running it will die like someone shut the key off. Does anyone have a list of what wires need to be hooked up? I had to have missed something and i think it is a 12v switched wire or 2.Any help is greatly appreciated.Thanks in advance,Ron
