Screening mouse access in Cirrus...
- Replies 20
- Views 5.1k
flagmanruss 10 posts
oldschool 6 posts
Mopar1973Man 2 posts
Rogan 2 posts
That was what I wanted the shop to do while I had the Cirrus in. They didn't. The mechanic said he freed the cowel enough (the hood hinges extend into the cowel area) enough to view the inlet screen which he claims is intact & tighter than my expander metal. The only place mice can get into is the heater cage & heater core. It's a total "son-on-a-female-dog" for me to pull the heater & reach in by hand & clean it out... and worse still trying to hold the blower motor & install the screws. I'm calling BS on him. There's NO PLACE ELSE in the car with mice. There's no other way in from the outside. There MUST BE a defect in the plastic screen. The plastic cowel part cracked when he was working on it (evidentally). I think he got into trouble & decided to stop. However, getting mice into the car makes me crazy, stinks up the car, spoils heating & cooling. The front of the cowel is held by a rubber seal at the top of the firewall.The back sits against the windshield held down by a few screws. But the windshield wiper arms come through it. I've tried before & got as far as the wiper arms. I think there's a nut under a plastic cover on each arm. The shaft & arm are serated. Gotta be a snug fit! If I mark each arm... what do I need a small puller to pop the arms off? What kind of puller do I need? There just has to be a defect in that screen.
