High Idle & MPG Fooler
- Replies 47
- Views 10.4k
Mopar1973Man 17 posts
SNKEBIT 13 posts
ISX 6 posts
safn1949 4 posts
Has anyone tried a stacked rotary switch similar to the switch on the bottom of pg 3 of the attached link to get everything into one switch with multiple positions for each of the functions/combinations needed to get both the High Idle & MPG Foolers into one pkg? I haven't sat down and sketched it out to see if it's even possible, just thought I'd check before playing it all out. It would require more then one of each resistor but they're cheap and would reduce the wires through the firewall to 4 and just one switch. No idea how many "stacks" the switch would need or number of "load" terminals for all the possible combinations involved but I'll work that out. It is more complicated then the original design but would result in a cleaner install. Would definitely need an index list for all the positions. Input on the concept would be greatly appreciated. http://www.alliedelec.com/images/products/datasheets/bm/NKK_SWITCHES_OF_AMERICA/70192244.pdf
