Ok, so here's the deal. I took my truck on a 1200 mile round trip to see family for thanksgiving, and on the way there the truck ran great. I averaged 19.67 MPG, but I was empty and not pulling a trailer. So then on the way back I was pulling a 24 foot flatbed trailer hauling a steel flatbed that I am going to put on my truck (weighs a couple hundred pounds). The truck had no power and got 10.32 MPG on the return trip. Also the ABS and BRAKE lights are now on and when I rev above 2300 RPM's I can hear a hissing noise from behind the dash, it sounds like it is comming from right behind the airbag on/off switch area, but it is hard to tell for sure (also it makes this noise even in neutral revving the engine).I also noticed that I was getting no black smoke at all, not even when I would go into a long hill and push the throttle all the way, it almost feels like I don't have any throttle after 3/4. I was having to down shift, and barely dragging over the top at 45-50 on hills that I usually pull in 5th at 70-75. So I stopped and looked things over and found nothing obvious wrong, so I unhooked my van aken chip to see if that changed anything, it didn't seem to make any difference, actually maybe a little less power if anything.At first I thought that I wasn't getting any boost pressure (I don't have a gauge on it), but if that is the case I should have black smoke. It feels like it isn't getting enough fuel maybe.Any ideas of what I should be looking at would be greatly appreciated, because I have to take it again this weekend on a snowmobiling trip.Thanks in advance Oh, I also pulled the codes and only got a P1693 code, I can't get the cheap code reader that I borrowed to show the companion codes that would go along with the P1693 code.
