Need Someone Creative
- Replies 11
- Views 2.4k
ISX 5 posts
Wild and Free 3 posts
bjytech 2 posts
Mopar1973Man 1 post
I cannot figure out a format to make this work how I want. It's a tree of wires meaning you start with the shutoff solenoid with 3 wires coming out of it. I have the wire colors listed in the orange and then I have where the wire goes. If the wire goes to its final destination, it is colored red (as is the case for the ground). If not, it is green meaning you can keep going. Each orange being the wire to the next destination from the last green cell followed by the new destination under the orange.
Simple, until you end up with something that does not leave with just one. The shutoff solenoid relay being the 3rd wire is listed with 3 orange wires coming out of it. Because there was the brown wire coming from the shutoff itself, this means there is a total of 4 wires coming out of the relay. So I list the other 3 since they are all possible culprits. Each one terminates except the last one, so not much of a problem, yet.
If we use the middle wire for example, it would be traced like this. LT GRN/BLK wire comes out of FSS and goes to fuse block, it then goes from the fuse block along a DK BLU wire to the ignition switch, it then from the ignition switch along a red wire to fuse 3, it then goes from fuse 3 along a red wire to the battery. At that point there are no more places to go, so it terminates.
Then the starter motor relay has another 3 wires and now it starts to get ugly. If the one didn't terminate at the battery, I would have 2 wires not terminating and it would create a list that you wouldn't know which came from where. I made a gap between the 2 to make it easier for the time being.
Because of this variable multiplying, something as simple as a family tree design doesn't seem to work with excel's "cell" format.
Do you guys have any idea, even if you don't think it could be done in excel, that could make it work perfectly?
