Truck won't start
I have a 98.5 which don't want to start, just replaced the IP around 5000 miles, has no codes, FP 15 WOT 17 idle, Battery's are new. No AC from the alt. I have fuel to the injectors. when it will start runs strong, idles great. Have reset the APPS, any ideas? no mods except gauges.
  • Replies 5
  • Views 1.7k
Is it a crank but no fire situation?
Does it smoke when cranking it? If not double check for fuel at the injectors again while cranking, sounds like an air leak or something along those lines.
I believe you hit the nail on the head, I just went out and checked there is fuel all over the starter. I have a DDRP on it, when it quits snowing and warms up a little I will find the leak and fix it. I don't use the truck much in the winter just for towing a RV in the summer but I like to keep it dependable. Thanks for all the info will post up when I get it fixed.
Found the leak, It was the "O" ring in my FASS DDRP. took it apart and replaced the O ring no leaks trucks starts and run's great.. Thanks for the help
