- Replies 17
- Views 4.3k
paul99 9 posts
diesel4life 4 posts
Mopar1973Man 3 posts
JAG1 1 post
my old pcm stopped working. i sent it in to rebuild i had no bus. it was not rebuildable so i got a different oneput it in and got error codes.PO113 Intake Air Temperature Circuit High InputP0118 Engine Coolant Temperature Circuit High InputP0340 Camshaft Position Sensor Circuit MalfunctionP0443 Evaporative Emission Control System Purge Control Valve Circuit MalfunctionP0505 Idle Control System MalfunctionP1282 Excessive Injection Control Pressureso i started with po340 and replaced cam sensor.no change with new computer my tach jumps, no alt charge, warning lights flicker really fast. and chimes all the time.traced crank wire sensor no shortsother than that it runs fine
