- Replies 8
- Views 2.1k
FlatTwin 4 posts
98whitelightnin 2 posts
stodg73 1 post
diesel4life 1 post
Just did a bunch of work on the truck getting ready for a drive.First thing put a "stealth" plate on the VP44. Its finished but the wire is not hooked to the Edge yet.Then did the final stages of the "big fuel line" mod to the truck. Ran the large line from the fuel filter housing to the VP44. Now when I put everything back together its throwing a "PO122" code. Drives fine, fuel pressure, throttle and so on is fine. Have tried to erase the code several times using the ScanGauge but guess its popping back up again.I am running out of time and need to take a 900 mile trip this weekend. As the truck is running fine, any reason why I cannot just drive it with the yellow engine light and the PO122 code showing? Thx,FT
