New turbo=Worse fuel mileage
- Replies 6
- Views 2k
Wild and Free 2 posts
Buzzinhalfdozen 2 posts
JOHNFAK 1 post
Texas CTD 1 post
Hello all, I recently replaced my stock turbo because i noticed it was leaking some oil by and it had some end play. It just so happens I came into a sweet deal on a slightly used BD super B. This turbo is for a 2003 cummins but the only difference I could find for install was changing the exhaust downpipe. So the problem is now I'm down about 2-3 mpg. There is a noticable power gain and broader torque curve but peak power seems to be at about the same RPM as it was before. I am not having much luck finding specs. for this turbo but everything I've read says its not much bigger than stock other than the exhaust housing is quite a bit larger. Any input would be appreciated on how to get my MPG back.
