- Replies 4
- Views 1.7k
Mopar1973Man 2 posts
klcammie 1 post
CUMMINSDIESELPWR 1 post
Thanks to all that share their knowledge. I just did the valve lash adjustment. Only took 4 hours. Not to bad for first time. Thank you Mopar1973man for your GREAT article with pix. Now onto my next project swap out the injectors for some RV 275. Couple more paydays then back here to get the info needed to do the job. The change in the sound at idle was amazing. Seat of the pants I would say 25-30% better running, seemed to get up to speed faster, will have to be careful already spun tires. Most of the valves were loose. intakes were .012-.013, exhaust .022-.023. I guess not to far out for 217778 miles.THANKS AGAIN!!!!!!!!!!!
