Thanks
Thanks to all that share their knowledge. I just did the valve lash adjustment. Only took 4 hours. Not to bad for first time. Thank you Mopar1973man for your GREAT article with pix. Now onto my next project swap out the injectors for some RV 275. Couple more paydays then back here to get the info needed to do the job. The change in the sound at idle was amazing. Seat of the pants I would say 25-30% better running, seemed to get up to speed faster, will have to be careful already spun tires. Most of the valves were loose. intakes were .012-.013, exhaust .022-.023. I guess not to far out for 217778 miles.THANKS AGAIN!!!!!!!!!!!
  • Replies 4
  • Views 1.9k
Yeah that wasn't too bad being that the valve lash could be....Intake - 0.006 to 0.015Exhaust - 0.015 to 0.030Some of use run slightly tighter lash settings too. I'm running 0.008 and 0.018. This give a illusion of a slightly bigger cam profile.
Yeah that wasn't too bad being that the valve lash could be.... Intake - 0.006 to 0.015 Exhaust - 0.015 to 0.030 Some of use run slightly tighter lash settings too. I'm running 0.008 and 0.018. This give a illusion of a slightly bigger cam profile.
im gonna redo mine to these settings 8/18
Yeah I seen where some like you run tighter, but since this was the first for me I tried to stay close to specs. In the nexst month or two will be installing the new RV275s so maybe then will run the lash to .008 and .018.
