4wd drive light always dimly lit
- Replies 12
- Views 2.4k
Mopar1973Man 4 posts
scummins 3 posts
MnTom 1 post
rancherman 1 post
Hi Guys, I noticed that my four wheel drive light is always on but dimly lit. The 4wd drive actuator and switch are fully functional. I have provided the wiring diagram in the following link. The 4wd is switched on the ground side of the circuit. I have power after the switch but loose it before the abs sensor switch and at the 4wd light connection to the dash. i believe that i have a leaking ground, broken wire, or bad connection either before or at joint connector no. 3. does anyone know where this is located? Thanks. http://articles.mopar1973man.com/images/2ndgen24v/antilock-brake-system/4w-abs-2.jpg
