Transfer case grenaded-swapped out, still issues
- Replies 18
- Views 5.7k
dennhop 9 posts
Wild and Free 5 posts
CUMMINSDIESELPWR 2 posts
hex0rz 1 post
So my NP241 DHD, with the two piece tailhousing decided to grenade-
Buddy sent me a DLD to put in for the time being. I installed it, and noticed that the two retaining notches on the pinion yoke had sheared off...I figured it may or may not hold, with the ujoint straps, but I tried to drive it into work...and promptly slung the driveshaft off. The ujoint caps flung off, and the driveshaft dropped.
So, I drove it home in 4 wheel drive, and parked it. Ordered a new pinion yoke from Rock Auto, and overnighted it. Got it installed tonight, new ujoint, and got the driveshaft in. I took it for a test drive, and I now have a bad vibration as soon as I hit 3rd gear, before I really get into it...under light acceleration, it starts getting bad.
in 1st and 2nd, as long as I'm out of the throttle, it's ok, but as soon as I start to get speed, the vibration gets worse.
I tried taking a video of the rear pinion, and it's hopefully loading to youtube right now, so I'll get the link up.
edit:
I noticed 2 things tonight and thought of a 3rd, that could potentially be a problem-
1. When I installed the ujoint in the driveshaft, for the pinion yoke, I couldn't get the ears to loosen back up. I tried the normal-hit the ears with a hammer, to loosen the joint back, but that failed. I figured I'd throw it in and drive it easy, to see if it would loosen up. I'll have to pull it again to see if it does.
2. The DLD is definitely shorter than the DHD... I took pictures to show how much the slipyoke fits on the Tcase output shaft-it's about 1.5 inches.
The 3rd thing I thought of, was could I have unbalanced the Dshaft when it slung out?
I'm at a loss right now. Been driving the wife's Jeep to work, so we're down to one vehicle until I can get this figured out. The gears shift fine, truck rolls smoothly at low speed, I just can't figure out what's going on with this thing.
