3rd Gen Truck Advice
- Replies 6
- Views 3.7k
JOHNFAK 2 posts
War Eagle 2 posts
Wild and Free 1 post
AH64ID 1 post
ok .... possibly looking to step up from my 2nd Gen to a 3rd gen. 04-07. Want to collect some info in case I do.1) Which years are best and why. Looking for a AUTO. Ideally 4WD but might have to settle for 2WD.2) Problems with years apart from sticking injectors.3) Anything to check for apart from normal ? How about pulling codes - just an OBDII scanner ?What mods done would indicate well looked after ...... eg normal LiftPump and guages ?? etcPlanning on checking for the following mainly.1) Codes and anything with transmission to indicate problem (fluid, clutch particulate) and any slipping under WOT.2) Blowby/Crank (where does it exit on these year trucks)3) Rust and Paint4) Joints, Tires, Brakes - normal wear or issues5) Check coolant and oil for any contamination. Check for any leaks.6) Rail Pressure - if I can {guages}.7) Steering ...... unsure how balanced and tight it should be compared to my semi-slop 2nd gen :)so on .....
