- Replies 34
- Views 19.2k
shelbyyoder5 12 posts
Wild and Free 9 posts
Mopar1973Man 5 posts
Racer Dan 4 posts
Where to start..
2001 dodge 2500 144,000 miles BHAF, Mia silencer ring, 5in exhaust, 35 in tires.
I just bought this truck 2 weeks ago went and test drove it everything good but the abs light was on he said he would get it fixed before he gave it to me and it was but now the speedo is stuck on 26mph but will go back to 0 when i turn the truck off. I tried the cluster test hoping it would fix it or something but still the same thing and it read no codes during that.
Now with the codes i have been doing my homework and looking around to try and figure this out myself but not to sure where the best place to start with so much wrong.
I did this through the odometer trick.
PPCU codes
P0122- Accelerator Position Sensor (APPS)Signal Voltage Too Low / APPS voltage input below the minimum acceptablevoltage
P0622- Generator Field Not Switching Properly /An open or shorted condition detected in the generator
field control circuit.
P1693- DTC Detected in Companion Module / A fault has been generated in the companion engine
control module.
P1765- Trans 12 Volt Supply Relay CTRL Circuit /An open or shorted condition is detected in the
Transmission Relay control circuit. This relay suppliespower to the TCC
PECU codes
control module
P0230- Transfer Pump (Lift Pump) CircuitOut of Range / Problem detected in fuel transfer pump circuits.
Also why driving it is not shifting right from i think 3rd to fourth going to 2 grand before it will shift or i have to let off and barely get back on, and also while going into over drive wot it will rev all the way to 3 grand and not shift unless i let off.
So my guess it the APPS sensor is either bad or i need to do this ats trick i found here https://www.atsdiesel.com/PDF/120505/4th%20hunt%2046%2047%20RE.pdf
but i dont really want to start hacking into wires right now.
Or is the altenator bad??
one more thing is there a relay located on the transmission or is it in with the fuses??
Any and all help would be highly apreciated!!!
