Weird sound diagnosed - good for those with the fuel boss or DTT
- Replies 7
- Views 2.5k
Lone Watie 2 posts
dobienut 2 posts
hex0rz 1 post
CTcummins24V 1 post
A few days ago I posted that I was hearing a 'rumbling' sound coming from my truck after starting off slowly, after the first start in the morning. A buddy of mine walked beside the truck the other morning when I left from work, and told me it was coming from the front of the engine compartment. I had already determined that the wheels, bearings, brakes were normal. I looked at the belt on my fuel boss, and it was very loose (the instructions for the fuel boss state not to have it too tight). Anyway, it was loose to the point where I could almost slip it off the pulleys. I got to thinking that maybe in the morning when the belt is stiff, it might be jumping the cogs on the pulley until it became more pliable, and might be making that sound. I tightened the belt up slightly, and sure enough my sound has gone away. Apparently, it was jumping the cogs enough to where the pulley was just barely grabbling the belt, and emitting my phantom noise. It was mere coincidence that the sound appeared after I had changed my crankshaft position sensor and had the starter out. Just wanted to pass this along in case anyone with these mechanical pumps ever hears a weird noise and has some trouble identifying it.
