Looking for Staff Members
I have a 4x4 truck with a 2wd nv5600. What all do i need to install the transfer case?
  • Replies 10
  • Views 1.6k
4wd nv5600 trail housing, output shaft, t-case???? Probably better to find a 4wd nv5600 or if you have a long bed extended cab, do a divorced np205.
yea doing some reading and need output, tail housing and tc. So far ive found a tc for about 475 shipped, then tail housing on ebay are around 150 or so and then the shaft which is over 400 on quad 4x4. Then the work. Damn :banghead:I saw someone selling a complete nv5600 4x4 for 3000 thats seems a little much no? It has over 200k on it too.
My truck is a shortbed. Why does it have to be a long bed?
Does not but I was thinking driveline angles with the short bed might not work. Try to find a setup under an old truck and measure the entire setup. I know of a guy on CF that had a 12v with a 2wd nv5600 and divorced np205 but it was a long bed.
Your t-case is mounted 18-20" behind your trans and there is a short driveshaft connecting the two. The rest of the setup is just like a married setup. You will have to make mounts to mount the t-case. Sent from my iPhone using Tapatalk - now Free
I talked to Fred and he said to pass his number on to you if you would like to ask him questions. I will send you a pm with his info. Sent from my iPhone using Tapatalk - now Free
