Compare B2 To Dino Diesel w/ 2 Cycle Oil
- Replies 6
- Views 3k
Mopar1973Man 2 posts
dorkweed 1 post
flagmanruss 1 post
Currently dino diesel here is $3.179 a gallon... Then B2 Diesel is $3.259.
So now if I was to fill up my truck (35 gallons) tank it would be (3.179 x 35 = $111.27) and Bio diesel is ($3.259 x 35 gallons = $114.07) that is a expense of ($114.07 - $111.27 = $2.80) extra. Remember I'm going to lose MPG so I'll be buying more fuel more often...
Now I buy a gallon of 2 cycle oil and it cost about $8 bucks. It will cover 128 gallons of diesel. It will cost me (128 ozs / $8 = 0.06 per ozs.) So if I fill up with dino diesel at ($3.179 x 35 gallons = $111.27) then add my 2 cycle at 128:1 ratio. (35 x $0.06 = $2.10) so my total bill will be ($111.27 + $2.10 = $113.37) which happens to be a difference of ($114.07 - $113.37 = $0.70 Savings)
Now over a 20K miles (1 year for me). I would save about (19 MPG / 20,000 miles = 1052 Gallons) So that is going to be (1,052 Galons x $3.179 = $3,344.31) total fuel cost for the year.
But If I switch to bio diesel. I would use (16 MPG / 20,000 = 1,250 Gallons) So that going to total up to (1,250 Gallons x $3.259 = $4,073.75) in Bio diesel. Which happens to be ($4,073.75 - $3,344.31 = $729.44 more I would be spending per year just for bio diesel...
With $729 dollars I can buy a hell of a toy for the truck with that kind of savings...
But here is the kicker... with 2 cycle oil I've increase MPG value by 2 to 3. Compared to losing it. So now lets figure it out... My cost per mile avg before 2 cycle was $0.18 cents a mile. Now with 2 cycle oil (128:1) ratio my cost per mile is down to $0.15 cents per mile. I've ran 2 cycle now for 20K miles. So ($0.18 - $0.15 = $0.03) now figure over the year running of 2 cycle oil. (20,000 x $0.03 = $600.00) This is how much I saved in a year. But I've spent between $60 to $80 dollars on 2 cycle for the year... So I'm still netting a total savings of ($600 - $80 = $520) per year.
Cost per mile graph. (Started using 2 cycle oil at 85K miles)
Those pennies add up quickly...
And not to mention I gain MPG and HP/TQ number with 2 cycle that you lose with BIO.
