FASS Pressure Question
- Replies 9
- Views 3k
Mopar1973Man 2 posts
FlatTwin 2 posts
BigRedNewfie 2 posts
CSM 1 post
I installed a FASS system (see my sig) on the weekend as per instructions except that I installed the supply to the stock filter housing (with gutted filter) to maintain my heater & pressure sensor. The other supply end connected to the stock sending unit and power directly to the battery. It did quiet down the engine a bit, less rattle.I have a small marshal 15psi mech. pressure gauge attached to the stock filter housing with a snubber. Before the install I saw 7psi @ idle with a slight drop @ wot, after the FASS install, I'm seeing only 10.8 or 11psi. I expected the advertised 16psi or at least 14. Has anyone else seen numbers this low after install? I haven't contacted FASS yet until I investigated a little further. Any comment or thoughts of where to look would be appreciated.
