- Replies 16
- Views 3.2k
hex0rz 7 posts
diesel4life 3 posts
Mopar1973Man 2 posts
MnTom 2 posts
:banghead: Dangit!Alright, so in my break caliper thread, I posted up some stuff, but no one replied.So in continuation from it, but a separate issue, I was trying to figure out what was going on with the hub, rotor, etc. I took the tire off and spun the rotor. The rotor did not look warped at all and no excessive wear. As I spun it though, I noticed something. I spun the rotor slowly and when you get to a point, there is resistance. A feeling as though it almost is a warped rotor. But sighting down it, its straight.So, I thought, maybe a u-joint? I took a pry bar and the joint did not have any slop. But as I spin the rotor, I did not recall hearing the noise I heard before. So, then I thought wheel hub assembly. I took the rotor with both hands and moved it in and out left to right. I get about 1/32" play.So, thinking it was the hub, I took the hub assembly/rotor off the axle. Now, what I'm seeing is the rotor is actually moving by itself on the hub! I took it to the parts store and he said he thought the studs were backing off.I'm gonna take it to an auto repair place, maybe have the studs replaced? They are chinese rotors, unfortunately, lifetime warranty from O'reilly's. I'm wondering if the holes in the rotors are not spec'ed out like OEM?Any rate, I'm wondering if the slop in the holes would cause that noise I'm hearing? Anyone even experience something like this?I decided to not replace the hub or u-joints as they do not seem worn to warrant replacement. I did pick up another caliper though and will be replacing that side tomorrow as well.Also, I had the wife turn the steering wheel so I could use the socket, extension method on popping off the hub and when she turned the wheel with the truck off, the power steering area just decided to puke out a bunch of fluid? WTF? Any ideas?
