Stihl MS 260 Pro
I had an MS 260 Pro given to me because they dropped a tree on it and it needs a lot of parts to be usable again. Even using cheap Chinese replacement parts I'll be into it around $200 and I'd still need a bar and chain. Not really worth fixing unless maybe I can find a complete one with a bad engine pretty cheap. Any chance someone has a blown up one or maybe knows where one is at for a decent price?
  • Replies 7
  • Views 2.1k
Rather than fixing the smashed one just use it for parts for the running saw.
Actually the other saw in the pics is an MS 250 and isn't the same quality as the Pro model.
Is the carb, compression release, and adj oiler still serviceable?You might be better to just junk it.
The rest of the saw is in decent shape. All of the handles/plastic covers took a beating though. Biggest expense is the rear handle and fuel tank.
If you decide to part it out, let me know.
