Air dog 150 not working fuel relay clicking
Ok, so my fuel pump started not to kick on when the key is turned on or when the engine is bumped. So I went to the troubleshooting guide on the Airdogs website. It said to put a jumper wire where the fuse goes to see if it will kick on. Well I jumped the fuse and all of a sudden the fuel pump started clicking on and off repeatedly. So I turned the key off. Replaced the fuse and it keeps doing it. Everytime I turn the key to the on position, the fuel pump kicks on and off and there is a bunch of clicking noises in the fuse box in the engine compartment. It's like I'm turning the key on and off, on and off, on and offVery confused and don't know what to do. I tried scanning for codes, but the reader couldn't read anything, I assume because the fuse box was going crazy. Is it possible I jumped the wrong wires in the fuel relay and fried something? Thanks
  • Replies 27
  • Views 16.1k
It depends on what the intake temps are. If you start your truck for a minute, let the grid heaters cycle a few times, then shut it off and restart it the wts light is not going to stay on as long as before because the intake temps are still warm. Is there an issue with the way the truck is running?JR
It depends on what the intake temps are. If you start your truck for a minute, let the grid heaters cycle a few times, then shut it off and restart it the wts light is not going to stay on as long as before because the intake temps are still warm. Is there an issue with the way the truck is running? JR
Truck runs great, It always starts right up. Only thing wrong with it is it only get 13mpg. I drive it very easy too, just cant get any better mpgs. I wasn't sure if the ECM is going bad which is causing problems with the vp44/timing which is the reason behind the bad gas mileage. Gonna try some RV275 to see if it helps any.
If the VP has high miles then it could be a part of it. Usually the ecm will not effect mileage though unless there's some real driveability issues. Generally you will get a check engine light if the VP is maxed out on advancement but not always. Injectors you can always pull and have them pop tested to verify before you spend money on new ones unless your wanting to upgrade anyway.JR
If the VP has high miles then it could be a part of it. Usually the ecm will not effect mileage though unless there's some real driveability issues. Generally you will get a check engine light if the VP is maxed out on advancement but not always. Injectors you can always pull and have them pop tested to verify before you spend money on new ones unless your wanting to upgrade anyway. JR
Is there a way to tell if the VP has been replaced?
Some builders will put a sticker on the top of the pump but other than something like that no way that I know of.JR
They used to be spray painted black, now its hard telling, unless there is a marking. The last dozen I have done look just like the stock bosch ones.
Not to still this thread but I had similar issue happen last night when I hooked up my new mechanical gauges. I had fuel lines drained because I changed return line bolt in vp and added 2 ball valves on to air dog for easier filter change. So when I was ready to fire up the truck, I turned the key on and pump primed for few second just like usual and then I bumper the key without starting to prime and then I tried starting it and it cranked for bit but didn't even try to fire up. So I primed it again and gauge goes up to 18 or so then tried to start it again and after few cranks it fired up but my fuel pressure dropped to 0, I let it run for about 20 sec opened nidle valve up some more still 0 pressure so I shut it off. Did the key thing and got fuel pressure again, start the truck and no pressure. So then I hot wired aidog straight to the battery and fire up the truck and got pressure. What the hell?:think: Let it run for a few minutes like that shut it off hooked relay back up and it runs normal, 18-19 psi. What do you think cased that? And what controls that relay? ECM? Is that how it knows to prime for few seconds before start and like 30 second when you bum the key? P.S. I have another relay on fire wall I thought that was the one for aidog but when I jumped 30 and 87 fuel pump in tank kicked in, I didn't even know I had that one, air dog has a draw straw and was put in before I got the truck. Can I get rid of that pump all together? I'm going to pull the tank and put in a straw that goes in basket to fix 1/4 tank issue so ill have to get rid of that pump anyway. question is all the wiring for it can it be removed without issues since I'm guessing it was some recall thing anyway. Ok I'm getting lost in my own writing, so hopefully someone can point me in a right direction:ahhh: Thank you.
