- Replies 8
- Views 1.6k
jones154 3 posts
mopartechnician 2 posts
klcammie 1 post
dave110 1 post
my 2001 has been parked in a 45 degree shop for the last day and a half. i started it let in run for a couple min. i then drove it out side where its -11 let it run for a few more min. i then babied it down the road for a mile the next mile i gave it a little more throttle about the time it was going to switch into over drive it when from 2100 RPM and dropped down to around idle RPM then jumped up to about 1800 RPM... I then turned around went back home. I got back to shop put it in park and held it at 3000 then went to 3500 RPM ran fine. i then pulled on to road and put it to the floor ran great power was all there then drops to 1000 and back up to 1500 or so take my foot off and catches back up... i pulled it into shop flipped key 3 times and the fallowing codes come up 1693, 1682, 0500. I dont have a code reader at the moment so i cant read all the codesIt acts like it might be gelling up or starving for air....I have diesel treat in it and even the ten min it was out side it shouldnt have gelled up.. i also pulled the air cleaner and it was pretty dang clean.... I also put a new fuel filter in it less the 600 miles ago... any help will be greatly appreciated thanks
