- Replies 10
- Views 3.5k
MoparDave68 2 posts
mopartechnician 2 posts
JOHNFAK 1 post
SNKEBIT 1 post
Well it has come time to rebuild my transmission.
Ive recently replaced the governor solenoid and sensor, adjusted bands and replaced filter and fluids. Well now it is not down shifting. The forward band is worn beyond use, and I'm sure that with the shifting issues I've experienced over the last two year that the rest of the internal works are worn just as bad. Ive adjusted bands, changed fluid and filter, adjuster TV cable, replaced solenoid and sensor, and still no improvement. So it is just worn out, closing in on 200,000 miles with a stock tranny, I can't complain. :lol:So I'm doing the Sun Coast M3GA 3 Alto Transmission Kit, Sun COast Triple Disc Torque Converter, Sun Coast Billet FLex Plate/Fly Wheel, ARP Fly Wheel bolt upgrade, Sun Coast's governor solenoid upgrade it with housing, and Mag-Hytec 727 D Deep Dish Pan. What else should I change while in there? The rebuild kit from Sun Coast comes with every thing internal including shift kit for the valve body. But are there other parts I should do while Ive got the tranny on the bench, either to the truck or transmission. I am gonna replace the TV cable also as it is fraying up at the throttle connection. Thank guys.
