Newbie - Needs help with Startup Issues
- Replies 6
- Views 2.9k
guesswho512 2 posts
gassernomore 1 post
Wulf 1 post
gtvdad 1 post
Mike thank you for all you do. You have helped me by phone twice and am now joining your forum - and yes I need some help!!! 1999 Dodge RAM 3500 4x4 Diesel Dually. Can't get it started in the morning - even jumping it (especially in this colder 20 degree weather) takes a while. On first startup (at night it shows well) the headlights will dim greatly for a few seconds and brighten (and repeat). I assume this is the alternator kicking on and off. After awhile this affect goes away. Running for awhileit will charge up well and restart as needed. If we take short stops and starts will notice it progressively harder to start up again. Assumed the batteries (3 year old Walmart- MAXX 9 year batteries) and they tested out very well (huh?????) Do I have a voltage draw down some where? What of the ASD (Cummins forum has few answers here). I don't have access to codes computer. If it sits out all night (especially cold nights, I have to jump it) Was going to try disconnecting battery overnight and reconnecting to see if it will start up. have heard about plugging it in for the glow plugs/oil pan heater.. I don't know that I have this option? Does the alternator jneed replacing? I am at wits end with a newbie experience. Thanks in advance for all of your input... GTVDAD
